Exporting calculation results
             Command  |
             Path  |
             Export Braceworks Structure  |
             Braceworks  |
To export the results of the last calculation:
Select the command.
The Export Braceworks Structure dialog box opens.
             Parameter  |
             Description  |
             Export Format  |
             Select whether to export to an .stp file in DSTV format or to a SCIA Engineer XML format  |
             Load Combination  |
             Select <No Load Combination> or choose a load combination. The icon next to the combination indicates whether it is class- or layer-based.  |
             Selection  |
             Select whether the exported results should include all rigging objects in the drawing, or only a subset of selected or visible objects  |
